El índice de eficiencia es un índice sobre el consumo que necesita la fuente para generar el valor que indica. Lo cito textualmente:
"Changing the voltages from one level to another requires various circuits that will lose energy as it gets converted. This means that the amount of power in watts used by the power supply will be greater than the amount of watts of energy that is supplied to the internal components. This energy loss is generally transferred as heat to the power supply and is why most power supplies contain various fans to cool the components.
The big thing to remember is that if you computer uses 300W of power on the inside, it is using more power from the wall outlet. The question is, how much more? The efficiency rating of a power supply determines how much energy is wasted or lost when it converts the wall outlet power to the internal power components. For example, a 75% efficiency power supply that generates 300W of internal power would draw roughly 400W of power from the wall. The important thing to note about a power supply is that the efficiency rate will vary depending upon the load amount on the circuits as well as the condition of the of the circuits."
Esto quiere decir (para los que no lean en ingles) que por ejemplo, una fuente de 300W con un 75% de eficiencia, usara 400W del enchufe para generar esos 300W (300/0.75). Si una fuente es poco eficiente significa que en la cuenta de la luz no te saldrán esos 300w por hora, sino que 400.
Este es un mito comun que me parece vital que la gente lo entienda para que no gaste dinero de más. Lo unico que si es cierto al respecto es que las fuentes genericas o charchitas son inestables en la energia que entregan, por eso son peligrosas. Otra cosa es que PCF es distinto a efficiency rating.
Esop, si me equivoco corríjanme.
pd: creo que deberian dejar "pinned" esta discucion pues mucha gente, sin saber, compra cosas caras que de verdad no necesita.
Este tema ha sido editado por arayashiki: 13 March 2009 - 01:02 PM
Ingresar
Ayuda
Compartir
Del.icio.us
Twitter
Digg
Email
Facebook
Google
Mixx
Reddit
StumbleUpon
MultiCitas
